Crashing On Exit and Network Rendering
LFedit
I was having the problem before of modo crashing every time I close the Octane Render window. Then I found out I had to pause first and then close and it won't happen. (Which was talked about in another post) But now it seems to happen when I am using network rendering. It doesn't matter if I pause or not, when I use network rendering and close the Octane window it crashes modo.
OctaneRender 2.23.2 (2230002)
801 sp4
Which exact version number of the plugin are you using pls?
LFedit
How do I see this? Its not this one?
"OctaneRender 2.23.2 (2230002)"
rafaelcoppola
i have the same problem with 2_23_2_69 version
LFedit
That sounds about right for my version as well.
Thanks rafaelcoppola
I haven't had any other reports of this problem, and cannot reproduce it on my PC, so it appears something specific to your installation.
Can you pls try deleting your Modo801.cfg file and see if that resolves the problem. If not, can you try disabling your other plugins and see if that helps.
Addendum to the above post....I have now been able to reproduce the lockup when closing the Viewport whilst network rendering, and a fix will be in the next release (available in the next 24hrs).
LFedit
Thanks a ton for fixing that. I lost soooo much work when that was broken... Great support once again!
Return to “Foundry Modo”
