OctaneRender® for Maya® 2.23.2 - 7.7 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Maya® plugin, 64-bit.
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on OSX operating system (including and above 10.8).
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Implemented the animated ORBX export.
  • Implemented the support of new render passes.
  • Fixed the bug: crashed after the rendering of frame as HDR image with passes.
  • Fixed the multilayer EXR file saving during HDR image rendering.
  • Fixed the Maya 2016-specific bug: problems with setting Octane node's attributes when the attribute editors are opened both in the side-panel and in hypershader at the same time.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
OctaneRender for Maya - v7.7 OSX (17.6MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
