OctaneRender® for Maya® 2.23.2 - 7.7 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Implemented the animated ORBX export.
  • Implemented the support of new render passes.
  • Fixed the bug: crashed after the rendering of frame as HDR image with passes.
  • Fixed the multilayer EXR file saving during HDR image rendering.
  • Fixed the Maya 2016-specific bug: problems with setting Octane node's attributes when the attribute editors are opened both in the side-panel and in hypershader at the same time.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
OctaneRender for Maya - v7.7 Linux (19.1MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
matrix2012
Thank you for the new version. :)
1.
The Render Passes: Post processing missing in the version.
In the 2.23.2-7.6 version is the Post processing Render pass there.
.2.
The in Hypershade Material Viewer is not working properly.
The material is always Mat though the shader is Glossy.
sorry for my bad English.
Next version HERE.
Return to “Autodesk Maya”
