Treehouse Conference 2
Submitted By: a1x
If the viewer above does not display correctly for your device, you can load the viewer directly.
After reading in John Carmacks post that it's important to not have anything in the 1.5 meters radius I rearranged the robots around the viewer.
So please, if technically possible and if the phase 2 deadline still allows: I would like to submit this to the contest instead of the older version found here: http://render.otoy.com/forum/viewtopic.php?f=97&t=48284
thank you.
"Treehouse Conference 2" - By: a1x
I forgot the description:
With this Treehouse I wanted to create a setting that feels pleasant and relates to the possibilities of VR.
A treehouse seems to be the perfect setting because it reflects the freedom and the endless possibilites of VR. You're only limited by your own imagination just like you may have experienced treehouses in your childhood. So it's the perfect starting point for an adventure.
As a contrast I wanted to inhabit this world by mechanical characters that welcome you - the new arrival - in their lobby.
But some are more welcoming than others.
Here are the wips:
http://render.otoy.com/forum/viewtopic.php?f=99&t=48169
http://render.otoy.com/forum/viewtopic.php?f=99&t=48224
http://render.otoy.com/forum/viewtopic.php?f=99&t=48253
Illustrator Lena Schall helped me with the design of the robots: http://wesenkammer.de/index.php/neuigkeiten-blog
We had a lot of fun working on this and will surely submit something for the third round as well!
Here are the wips:
