Submitted By: robmar1705
If the viewer above does not display correctly for your device, you can load the viewer directly.
I'm the same of the "Instant of joy!"...I know, it sounds singular, but the goal of mine is make you feel an emotion.
I modeled the spider and converted it in low poly by ZBrush.
The high poly detail are in a normal map that I built by Topogun.
The Web are modeled with the grate Coweb plugin for 3dsMax.
I rendered the scene and many render passes by Octane standalone.
I've post produced the scene by Photoshop and After Effects.
