Stencil to Alpha After OO (Octane Override) broke?
LFedit
Hey guys,
When I use stencil in modo the plugin does a great job of converting that stencil to the opacity channel when I convert to a OO. But it puts the image I am using as an Alpha Image. Then it doesn't work. So then all I do is delete the Alpha Image, Create an RGB image and reassign it and it works.
Is this something on my end that I am doing wrong to constitute it as an "Alpha Image"? It seems like it is completely unnecessary when RGB works every time.
I am using 801 plugin OctaneRender 2.23.2 (2230002)
What do you have the Alpha Channel set to in the Texture Locator?
I am just looking at the release notes when this functionality was added....
1.52.0.60
- Added support for Stencil maps with Alpha Channel set to Alpha Only (which will result in an Octane Alpha Image being created)
LFedit
Bam got it working. I was using a JPEG. I had to use a png and delete the background so it was transparent in photoshop.
But when I do a OO and I use an rgb image it works with the black and white image...
I can't see any obvious difference between the on-the-fly conversion and the Octane Override for Stencils. If you have a simple sample scene which shows this - can you send it to me pls? There might be something simple I am missing...
LFedit
Well I got it working. I think it was because when I saved a black and white image as a jpeg it didn't have a correct alpha channel, like when I save a png with a transparent background.
About the conversions though. Is there a list somewhere of what convert and what doesn't . I will check over the docs in a minute. I almost always just start out with an octane override. But would sure be nice to just use conversions so it is easier to transfer materials between scenes.
Thanks paul
Return to “Foundry Modo”
