Hi guys,
First, thanks for doing a houdini plugin, very exciting stuff. Just bought a couple of titans for an upcoming job and are planning on using Octane with houdini.
Just a quick thing I noticed that happened repeatedly, When adding a displacement node to a Octane material node in Vops, if I have the IPR open and try to adjust
the "height" parameter; both houdini and octane crashes instantly. Regardless of texture etc, shader connections etc etc.
It is howver fine, if I just render it normally and then change it and re-render. The VOPS->IPR seems to be a bit flaky.
Hope this is useful.
-t
Displacement height paramter crashes IPR (and houdini)
C. RAM Capacity (i.e. 6 GB)
