Mayabatch render issue
Maskeline
HI.
Mayabatch unexpectedly quits after the firs frame render is completed.
Here the end of the maya renderlog
[quote]Octane: Refreshed image, 3006 samples per pixel of 3100
Octane: Refreshed image, 3016 samples per pixel of 3100
Octane: Refreshed image, 3025 samples per pixel of 3100
Octane: Refreshed image, 3035 samples per pixel of 3100
Octane: Refreshed image, 3045 samples per pixel of 3100
Octane: Refreshed image, 3054 samples per pixel of 3100
Octane: Refreshed image, 3064 samples per pixel of 3100
Octane: Refreshed image, 3074 samples per pixel of 3100
Octane: Refreshed image, 3084 samples per pixel of 3100
Octane: Refreshed image, 3093 samples per pixel of 3100
Octane: Refreshed image, 3100 samples per pixel of 3100
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_emit.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_difdir.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_difindir.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_refldir.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_reflindir.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_refr.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_sss.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_zd.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_mid.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_aocc.exr"
Octane: Frame 352 is rendered, saved tonemapped "OpenEXR" image to "X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/RENDER_C05_AES_Precedencias_Ani_07_L13.352_env.exr"
Result: X:/Trabajos/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/scenes/RENDER_C05_AES_Precedencias_Ani_07_L13__5788.mb
Fatal Error. Attempting to save in C:/Users/Elvira/AppData/Local/Temp/Elvira.20150623.1837.ma
// Maya exited with status -1073741819
Could you give me the scene?
Maskeline
I send you the link for download the file (rar compressed) in a private messagge
Anyway this issue only happens in one of our workstations.
The specs of this workstation:
- Windows 8 64 bits
- 16 Gb RAM
- Nvidia gtx 980
- Nvidia gtx 780 ti
Now i have change the OS to Windows 7 64bits. I will see the result of this change
Maskeline
Again the same problem. This time with a new scene and another workstation with windows 7 64b.
- Maya 2016 SP1
The end of mayaRenderLog
Octane: Refreshed image, 369 samples per pixel of 1024
Octane: Refreshed image, 424 samples per pixel of 1024
Octane: Refreshed image, 486 samples per pixel of 1024
Octane: Refreshed image, 556 samples per pixel of 1024
Octane: Refreshed image, 635 samples per pixel of 1024
Octane: Refreshed image, 724 samples per pixel of 1024
Octane: Refreshed image, 824 samples per pixel of 1024
Octane: Refreshed image, 933 samples per pixel of 1024
Octane: Refreshed image, 1024 samples per pixel of 1024
Octane: Frame 4 is rendered, saved tonemapped "OpenEXR" image to "D:/TRABAJOS/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/Test_03.004.exr"
Octane: Frame 4 is rendered, saved tonemapped "OpenEXR" image to "D:/TRABAJOS/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/Test_03.004_mvec.exr"
Octane: Frame 4 is rendered, saved tonemapped "OpenEXR" image to "D:/TRABAJOS/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/Test_03.004_lid.exr"
Octane: Frame 4 is rendered, saved tonemapped "OpenEXR" image to "D:/TRABAJOS/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/images/Test_03.004_lmask.exr"
Result: D:/TRABAJOS/AES_Software_aeronautico/AES_Compo/AES_3D/AES_Maya/scenes/Test_03__2580.ma
Fatal Error. Attempting to save in C:/Users/Blanca/AppData/Local/Temp/Blanca.20150627.1304.ma
// Maya exited with status -1073741811
Wenneker
We have this all the time.
I only render individual frames for this reason. Since the frame is stored it's a minor problem for me.
Frames that keep stuck at the last sample without saving an image are far more annoying.
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
Maskeline
For animation projects is a great problem.
Wenneker
We use a separate rendermanager for animation projects. (for all our renders actually)
With a chunk size set to 1 there is a bit of extra rendertime for starting the render again for each frame but for octane this has proven to give the smallest amount of re-renders. The reason we started doing this is because of lights that were only working on the first frame of a render. This may have been fixed by now haven't really checked.
Maskeline
Can you tell me what program you use for render management
Wenneker
We're using renderpal but there are plenty of others out there. Most have a free version limited to 3 or 4 nodes. I suggest you try and see which one works best for your situation.
RoyalRender Muster Smedge Deadline are a few of the others you could check out.
Maskeline
Thanks!!!
Return to “Autodesk Maya”
