Error?
LFedit
Could you tell me what this log means?
Started logging on 22.06.15 14:51:30
OctaneRender 2.23.2 (2230002)
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> failed to bind texture to device memory (data5)
device 0: failed to bind data texture 4 of context 0
CUDA error 1 on device 2: One or more of the parameters passed were not within an acceptable range of values.
CUDA error 1 on device 1: One or more of the parameters passed were not within an acceptable range of values.
device 2: failed to bind data texture 4 of context 0
device 1: failed to bind data texture 4 of context 0
I can't figure out the problem. Is it fixable?
Thanks!
Could be running out of memory (rendering resolution too high to fit in your VRAM?). Suggest rebooting and trying again. Is it only happening on that one scene? Try turning on Out Of Core textures.
LFedit
Thats what I thought it was. So I ended up deleting a bunch of pieces that couldn't be inside, restarted and tried again and it worked. It is cad data so it must have been that.
Return to “Foundry Modo”
