INSTALL problem
gold
I just had to do a clean install. I Used 2.23148, for windows. I see files in the Poser directory , but there is NO Octane in the Poser Render drop down.
Help please!
thanks
TRRazor
Did you install standalone as well?
The Poser plug-in won't work before one instance of standalone was installed as well.
You can get the most recent version here: http://render.otoy.com/forum/viewtopic.php?f=33&t=45529
2.23148
There was no Poser plugin of that version - are you sure you installed the correct plugin?
What does the octaneplugin.log file show?
gold
TRRazor wrote:Did you install standalone as well?
thanks alot, that seems to be the main problem.
gold
face_off wrote:
2.23148
Started logging on 21.06.15 08:04:19
OctaneRender 2.23.1 (2230001)
It seemed to install fine. Then installed latest standalone, per TRRazor advice. But activation was quite frustrating, requiring multiple attempts,
taking hours.
Looks to be finally acivated in poser now
TRRazor
Glad if it helped :)
Return to “Poser”
