Hi guys,
i found a work around for displacement+bump problem. See attached scene and image.
Displacement + bump trick
- Attachments
- disp+bump.zip
- (132.27 KiB) Downloaded 1114 times
very nice man!
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
What does this fix exactly please? I mean what was the issue people were having?
Ten
Ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
Simply displacement cant work with bump or normal maps.
But seems it can
But seems it can
https://yambo.me
https://yambo.me
wow, great find ahmed, it works also in standaloneaoktar wrote:Hi guys,
- gordonrobb
Can I ask (as I'm not sure from either of the node trees), which you're putting into what? Is the displacement going into the mix node? and the bump going in to the material? And Is it one material that you are putting into both inputs of the mix node? Also, what are you putting the mix value at?
hi gordon,
yes, exactly! the trick is to get advantage of the extra node for displacement in the mix material and to use the same material with bump in the double slots of the mix node
Since we use the same material twice, the amount node doesn't have any impact
Here is my simple scene for testing:
- philliplakis
thanks man
Win10 - 6700k - 32gb Ram - GTX Titan X (Pascal) + GTX 1080
