Eurofighter
samartin
Seriously liking OR, here's an old model, there are problems as I used partial UV's and the OBJ format doesn't like them! Hence no textures, let's hope if FBX is implemented then partial UV's won't be a problem!
Anyways 3 different views, the top 2 views are using the same HDR.
Oh and I only let the images cook for 2 mins, I am really impatient as I can't do anything else while things are cooking...
Win 7 Pro (x64) | Geforce 295GTX | Quad 2.4GHz | 4GB PC-6400
mlody47
i was first with plane ;P im topic below You and I got similar angles for my aircraft:)
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
James
IF you are impatient with waiting for things to render, set them rendering when you are off cooking or if you need to go to the toilet. Then you don't have to worry about not being able to use your computer ;)
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
radiance
nice :)
the 3rd one looks very good.
Radiance
samartin
Thanks, the model isn't quite as tight as I'd like it, plus I was just getting my head round modo at the time + budget constraints played a part.
It's also a shame that I never did UV it properly, maybe one day I will update areas.
The 3rd image is the only one where I enabled a slight amount of DOF :)
Sam
Can you make the second one and the third one a little higher res and more cooked ?
And add credits for gallery ;)
We need gallery material, not just test-renders
Please post separate renders, its better suited for the gallery
Very good model and renders :D
samartin
Sure I'd be more than happy to do a better/longer render! I'm cooking up something else at the moment, this will be a freeby model, shame I can't save the material attributes tho' :o(
I guess it won't be long before the BETA is available :o) No pressure there then!
samartin
Latest versions of the Eurofighter.
radiance
nice images,
but the first suffers from a lot of aliasing.
did you enable the 'filter' in the settings of the render kernel ?
Radiance
samartin
I hadn't enabled the filter as I didn't use it on the 1st render which is the one front on. That didn't have any aliasing issues, however I'm churning one out now with filter checked.
