Solid projection
heavypoly
Hi guys, does the octane plugin have an equivalent to Modo's solid projection type?
Vaughan
Hi. Solid projection mapping is not supported by the plugin. Pls see http://render.otoy.com/universe.php#42P ... %20Mapping for the supported projection mapping modes.
heavypoly
face_off wrote:Hi. Solid projection mapping is not supported by the plugin. Pls see http://render.otoy.com/universe.php#42P ... %20Mapping for the supported projection mapping modes.
Thanks Paul. The reason I ask is because solid is one of my go to projection types in modo. Is it something that might be included in future?
There is not an Octane projection mode to match the Modo Solid projection, so it's something that would need to be added to Octane Standalone. May I suggest requesting it as a feature request in the Octane Standalone 2.23.2 thread so that the Otoy devs are aware of your requirement.
Rafael-Vallaperde
Hey guys,
Vaughan, try box projection, it works almost the same way.
Cheers
heavypoly
You're right, it's totally the same. Thanks Raf :)
Return to “Foundry Modo”
