Hi Everyone, this is a kitchen project I've been working on for my website portfolio.
Nearly there I think!
kitchen
- MaTtY631990
Hi Ardri
This is good image here but I would avoid using hotpixel removal because you have lost a lot of quality here. I know it is for show for still details are missing from image. What kernel was used and what render time did you get for this image?
thanks MaTtY631990,
I have turned off hot pixel remover, didnt reaslise that the spinner works in reverse!!
Think it looks much sharper now but render time using the PMC kernel was over 6 hrs!
www.designxyz.co.uk
Autodesk Inventor lt Suite
Autodesk 3DS MAX DESIGN 2015
Octane for MAX version 2.04
HP Z620 workstaion, 2 x Xeon E5-2620@2GHZ, 32 GB RAM
Nvidia Quadro K4000
Cubix Xpander series 2 with 2 X Nvidia GTX TITAN
Nvidia Quadro K4000
- MaTtY631990
Yes, much better now, but why use PMC. I would only use PMC if difficult caustics were what you are after.
Pathtracing is optimised a lot and would render this scene a lot faster.
i was under the impression that PMC was just better than path tracing? I usually do studio based renders which render very quickly so am not usually concerned with render time.
I will try it with path tracing and see how much faster it is, cheers.
oh by the way what did you mean by details being missing?
www.designxyz.co.uk
Nvidia Quadro K4000
Nvidia Quadro K4000
- MaTtY631990
I think that using a low hotpixel value clamps out some detail in the render. There are other options like gi clamp to use which would be better will keep the sharpness. Another option is to try rendering at a larger resolution until it looks good enough and then downsample the render.Ardri wrote:i was under the impression that PMC was just better than path tracing? I usually do studio based renders which render very quickly so am not usually concerned with render time.
Thanks for your help on this , much appreciated
www.designxyz.co.uk
Nvidia Quadro K4000
Nvidia Quadro K4000
Hi
I think it's a nice image but you need to work on your lighting ( no life to it)
The centre cabinet is very flat looking it has no dimensionality , you need to add some lighting to bring out the form of the cabinet. The image in the window is distracting, it looks pasted in.
The lighting above the centre cabinet in the hanging lights does not look correct, you usually can't see the filament in the bulb. I see no effect of the lights on the counter plus photographers usually correct for differences in the color temperature of the lights.
Windows 10 | 1950x threadripper |64gb Ram | EVGA GTX1080 ti x3 |
Modo 13 64bit
Lightwave 2018
Nvidia driver 419.67
Octane modo plugin version 4.04.0.145
Octane lightwave plugin version 4.04
Modo 13 64bit
Lightwave 2018
