OctaneRender for Nuke (Linux) 2.24.1 [TEST]
This thread has been merged with the Windows release version. Pls navigate to viewtopic.php?f=91&t=45763.
JohnMesh
Hey face,
thanks for this awesome plugin in nuke.
Installation went well face, i installed this to a custom location /usr/OFX/Plugins/OctaneForNuke/. After that i edited the init.py inside nuke's /usr/foundry/Nuke9.0v5/plugins/ folder and add this:
    nuke.pluginAddPath("/usr/OFX/Plugins/OctaneForNuke", addToSysPath=False)
Nuke 9.0v5 start and loads the plugin fine.
When i try to start OctaneRender i got the following:
    /usr/foundry/Nuke9.0v5/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/OFX/Plugins/OctaneForNuke/OctaneRender.so)
Is it correct that liboctane.so is also placed into /usr/OFX/Plugins/OctaneForNuke/ ?
I have the following files inside this folder:
    /usr/OFX/Plugins/OctaneForNuke$ ls
    liboctane.so
    ocsWriter.so
    menu.py
    octane.dat
    OctaneRender.so
    OctaneReferenceGeometry.so
Hi John - did you include the LD_PRELOAD environment variable? http://render.otoy.com/universe.php#43Installation
And yes, lboctane.so needs to be in the same folder as OctaneRender.so.
JohnMesh
Thanks face for this headup,
LD_PRELOAD included now for
env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libstdc++.so.6 /usr/foundry/Nuke9.0v5/Nuke9.0
/usr/foundry/Nuke9.0v5/Nuke9.0: /usr/foundry/Nuke9.0v5/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/x86_64-linux-gnu/libstdc++.so.6)
Thanks John. The LD_PRELOAD is required because whilst both Nuke and Octane are compiled with the same version of the C++ compiler, the libraries shipped with Nuke are earlier that those required by Octane. The LD_PRELOAD is working for me because I have installed the correct libraries, but they are probably not on your system. This is a serious impediment to running Nuke on Linux which I think TheFoundry need to address. It's been an issue for many years. There are quite a few threads on it - including http://community.thefoundry.co.uk/discu ... 1&t=104371 and http://community.thefoundry.co.uk/discu ... ld_preload.
I think the solution is to add libgcc_s.so.1 to tge LD_PRELOAD environment variable.
So it will be something like:
setenv LD_PRELOAD "/usr/lib/libstdc++.so.6:/lib64/libgcc_s.so.1"
You can also just rename "/usr/foundry/Nuke9.0v5/libstdc++.so.6" and "/usr/foundry/Nuke9.0v5/libgcc_s.so.1".
Good luck.
JohnMesh
face_off wrote: You can also just rename "/usr/foundry/Nuke9.0v5/libstdc++.so.6" and "/usr/foundry/Nuke9.0v5/libgcc_s.so.1".
That solved the issue. I will test the plug now and reply here if i found something
JohnMesh
One last thing before i dig into it...
I see its already available as BETA license, so can i just purchase it and use it permanently for nuke?
Yes John - the same plugin license will work with either the Windows or Linux version (and the OSX version too if I can ever get it to compile).
JohnMesh
I already throwed some bucks over ;-)
Keep on the good linux support!!
Thanks John :-)
