Hi everyone,
We are building 2 machines dedicated to OctaneVR and are wondering which graphic card is the best: GeForce Titan X or Titan Z?
Thanks for your help!
KV
OctaneVR / Nvidia GeForce Graphic Cards
As OctaneVR uses the OctaneRender engine, you can compare the performance of GPU's using OctaneBench.
View OctaneBench
View OctaneBench
Depends if you need 6gb or 12 ggb vram. Titan Z is 6gb for Octane and Titan X is 12gb.
If you think 6 gb is enough, then it also depends on how many cards you can stick in your Build.
Titan Z has more renderpower, but depending on your config you can have more X or more Z.
With watercooling i.e. I can have 3 Z's in a current config instead of 2 with aircooling.
So, a config on water with 4xZ will perform better then 4xX, but has 'only' 6 gb.
And it depends on your budget, and the Z's are hard to get these days, so probably you end up with the great X
This is a nice thread about choice X or Z
http://render.otoy.com/forum/viewtopic. ... nz#p231966
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Thanks guys!
Here's what we do: we are building 2 machines. the first one with 2 x Titan X and the other one with 2 x Titan Z
Motherboard: ASUS ATX DDR4 3000 LGA 2011-3 Motherboards X99-DELUXE/U3.1
CPU: Intel Core i7-5960X Haswell-E 8-Core 3.0GHz LGA 2011-v3 140W Desktop Processor BX80648I75960X
RAM: Corsair Vengeance LPX 64GB (8 x 8GB) DDR4 DRAM 2666MHz C16 memory kit for DDR4 Systems DDR4 2666 MT/s (PC4-21300) (CMK64GX4M8A2666C16)
I'll let you know which one works better.
KV
www.noodles.link
KV
www.noodles.link
