If this feature is enabled, do I have to have the above option enabled too (Update Materials)? In other words, does Update Materials have to be turned on in order for Only materials in enabled obj. to work? I understand that using Only materials enabled means that I have to enable each object that I want the material to be updated using the Octane_Object_Properties. I'm just worried that if I don't turn on Update Materials, then Only materials... won't update anything.
Is it me or is this the most bizarre load of guff you've ever read?
Update scene Only materials in enabled obj.
Vote for Juanjo!
Yes, the update materials only in the enabled objects is only available in the full "Update Materials" option is enabled. With both options enabled, the materials are updated only in the objects that have the custom object plugin with the update materials option enabled.
Thanks for putting my mind at ease. I was afraid by ticking the first item it was updating all the materials regardless of the second item. I admit, I think I was being a bit dense!
Vote for Juanjo!
