Is there a Render Boolean equivalent?
marcus1070
Hi guys!
Do you know if there's an equivalent way to get the Render Boolean effect on octane?
Anything that could make an object appear in a animation...
Thank you very much!
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Nvidia driver version: 516.94
- Cinema 4d r25
- Plugin version Studio+ 2022.1(r7)
http://www.marcusrizzo.com
Hi - I suspect this will be supported in the next major release of the plugin (which uses the new Modo Rendercache API). If you send me your scene above I can check if you like.
marcus1070
It would be great to get this... a way that i think to do something like this is with camera near clip,.. but in a axis.. maybe hehe
well.. the scene is attached
render boolean scene.zip
(8.08 KiB) Downloaded 244 times
- Win 10 Pro 64bit
- 64gb Ram
- RTX 3090
- RTX 2080
- Cinema 4d r25
Thanks for posting that scene. Unfortunately the new Modo Rendercache does not yet support Render Booleans. I will submit a feature request to TheFoundry to add this.
pixteur
Any news on this?
Any news on this?
I reported it to Modo devs as a feature request, but it has no yet been implemented. If you really want this, you will need to put pressure on TheFoundry - otherwise I suspect it will never be implemented.
Return to “Foundry Modo”
