I've encountered the "Stopping rendering after one frame" - the scene with animation rendered fine before. I've hidden one (!) polygon via a set selection command and started rerendering. Now it will stop after one frame, no matter how I set my render settings (Manual/All Frames/Etc)
I've cleaned up all the materials, and tried to make head or tail from the octane log file:
---- FRAME 0 DOC:0x0000000167F8BFC0 vpfps:25 rfps:25 first:1 fullUpd:0 updMthd:0 nodes:130 links:0 ----
FileName::toJuceFile() can be called only on absolute file names
Tried to access pin via an invalid ID P_EFFICIENCY (39)
Tried to access null node pin
Can't connect node 'RGB image' (NT_TEX_IMAGE, 0x7f9d5f6c6d60) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x126382e80)
--------------------------- EXPORT LOG ---------------------------
Export materials time= 4815.767 ms
Collect objects time= 22.35 ms
Meshes creation time = 1026.501 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 145.694 ms
Total export Time = 37350.543 msAny help would be HIGHLY appreciated
best,
yp
