Products with transparency for v4
ajr0717
Some products involve transparency because V4 seems to be dissolving into the air
http://www.renderosity.com/mod/bcs/ghos ... ia-4/55993
An example is ghost by adamthwaites.
Can octane accomplish something like this if I purchase this product?
Xipomus
Octane has Opacity for transparency.. you'll probably want to play around with the normal v4/m4 to test it.
And to make it look like you want it.
But yeah Octane can definitely do this. Individual textures can have different opacity values.. so ghosts can be done easily.
Good luck.
Having the ghost semi-transparent is trivial. But having the ghost go from opaque to transparent top to bottom will need a trans map (which those products probably have). The VR version of the plugin can be used at no cost for the next 2 months.
ajr0717
Why would I use the VR version
Return to “Poser”
