IES Tilt File error
bpzen
Hi there,
I am trying to set up IES lights for a scene, I made the lights blckbody and put the IES file on the distrubution pin however when the scene loads i am getting an error
Separate IES Tilt Files not supported
I have 2 different lights using 2 diff IES maps, is that the issue? Can I only use one type of IES per scene?
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Hi. I haven't seen this error before, so I will need to check with Otoy. However at a guess it appears your IES files are in an unsupported format. Try download IES files from a different source. You can have an unlimited number of IES files in a scene.
bpzen
thanks Paul, yea it seems one of the 3 i was trying to use gives me this error, i can load the other 2 fine.
Can you pls send me the IES file which didn't work, and I will forward it to Otoy.
Return to “Poser”
