OctaneRender® for Maya® 2.23.2 - 7.3 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Maya® plugin, 64-bit.
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on OSX operating system (including and above 10.8).
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • New 2.23.2 engine.
  • New "Cube map" camera modes added: now you can render different faces of cube map separately.
Installation:
DOWNLOAD
OctaneRender for Maya - v7.3 OSX (17.6MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
10Polarbears
I my case I am unable to render separate cube map faces.
The setting makes no difference.
I was hoping that I could render to the VR cube map.
Can't do that either.
Have you set the camera to "Panoramic"?
p3taoctane
Scatter node?
JimStar... I see there is a scatter geometry type under the extra attributes.
How does one plug a scatter file into that node?
In-other-words can I load a scatter file and use it to distribute geom in Maya?
Peter
p3taoctane
Any word on scatter file... ya... na... later? :D
TBFX
p3taoctane wrote:Any word on scatter file... ya... na... later? :D
Hi Peter,
The scatter geometry type is just for instancing, it works like the movable proxy geo type but instead of being re loaded every frame it will only be loaded on the first frame rendered. It is useful if you have a load of instances that are not animated and are rendering an animation. You set it on the base geo that you are instancing, just like you would movable proxy, and then instance that geo in any of the usual ways.
T.
p3taoctane
Ah thanks ... TBFX I got it.
Do you know of any plugin for maya that lets you load a data file that lets you "scatter" a bunch of instances according to the xyz in the data file?
Welcome any suggestions.
Peter
10Polarbears
Apologies for the delay in responding.
No I didn't have panorama set at the camera.
My bad. It does work.
Next version HERE.
Return to “Autodesk Maya”
