OctaneRender® for Maya® 2.23.2 - 7.3 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • New 2.23.2 engine.
  • New "Cube map" camera modes added: now you can render different faces of cube map separately.
DOWNLOAD
OctaneRender for Maya 2.23.2 - 7.3 (12.3MB autoinstaller file)
OctaneRender for Maya 2.23.2 - 7.3 Demo (10.8MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
Jolbertoquini
Thanks for upadate Jim, I had write this question could you give one help on that, Please?
..."Hi Guys,
I just was wondering how to see a backplate on the render (Maya)? any advise...I know in the standalone is possible but in Maya doesn't look to be possible. :idea: maybe a option at the camera calling the background option on the standalone so we could plug a image for the background at the camera?
Thanks Guys"....
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
itsallgoode9
...New 2.23.2 engine."
you're ahead of the game on this one, the dev build thread still only has the 2.22.2 engine.! :lol: :mrgreen:
RickToxik
This release crashes for me in maya 2015. I cannot save a - empty - scene without maya crashing.
RickToxik wrote:This release crashes for me in maya 2015. I cannot save a - empty - scene without maya crashing.
Do you mean only empty scene causes the crash?.. Is it OK if you save non-empty scene?
RickToxik
No, I was not able to save any scene. I went back and re-installed the stable build (2.11). Now this morning it crashed maya when I tried to re-open the scene I'm working on, I uninstalled octane for maya and the scene re-opens fine. If I am the only one experiencing constant crashes, I would suggest you investigate if a conflict between arnold and octane could be causing that, as both plugins adds custom attributes in the shape tabs of all objects. I had it working yesterday with the stable build but crashes on opening and saving scenes is critical...
Refracty
If the number of render frames is the same length as the keyframe animation there is an error (in the render log with verbose mode):
Error: Subframe motion blur animation requires extra frame after the animation's end frame.
Would be great if Octane adds a key automatically in the end of the anim.
abeoctane
Hi Jim, this version of octane still have a lot of bugs in the materials, I did a project with some examples and I recorded some videos included in the zip file, hope this helps to fix them. thanks.
materials_bugs.zip
(15.74 MiB) Downloaded 336 times
abeoctane
Thank you for report.
I'm working on it...;)
Next version HERE.
Return to “Autodesk Maya”
