cos there is much complains about performance in the 400 series. thanks
gtx 580 maya performance
hi all pls has anyone tried out the new gtx 580 in maya in regards to view port performance, i just placed my order and sincerely hope am on d right part
gigabyte mobo, core2quad, 8gb ram, x2 pny gtx 580,
hp pavilion hdx series(desktop replacement) 4gb ram, gt 8800
win7 x64bit, octane 2.3 v5
- Slimshader
I haven't had any problems with the maya 2011 plugin and 2 x gtx 460's actually.
- infernoVFX
I have Asus ENGTX 580, works like a charm in Maya 2011 x64 subscription package, the last scene i was working on had around 4 000 000 triangles, and with 16x antialiasing enabled ("override any application setting" in nvidia control panel) the workflow was VERY SMOOTH. Scrolling and working with the materials in the hypershade works faster, which is for recommendation, this was a bottleneck if you don't have a quadro card.... All in all, there's no problems whatsoever, nothing. Well, you'll see for yourself when you get the card
All the best,
Voja
All the best,
Voja
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
@ simshader thanks
i wish octane cld work with displacement map then the improved tesellation feature in 580 wld really come in handy
