OctaneRender® for Maya® 2.23.1 - 7.1 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • New 2.23.1 engine.
  • Added the "Cube map" mode for panoramic camera.
  • Brought back the kernel option "keep environment".
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.23.1 - 7.1 (12.3MB autoinstaller file)
OctaneRender for Maya 2.23.1 - 7.1 Demo (10.8MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
prodviz
Cheers Jim.
Reading the forums, I take it the 'Cube map' is for VR output?
edit:
Awesome, Hypershade is there on startup, cheers for that.
But no procedural pin on displacement node... as yet :(
Refracty
This might be a bug: When I try to render an animation with motion blur (any MB Mode) the status line saya "rendering completed" after a few seconds but there is no progress or image result. There is no info in the renderlog file. When I uncheck motion blur in the settings tab, the sequence renders fine. Any ideas?
I have two other questions:
When I set the scene to Z Up - The camera is not shown in the IPR correctly. It seems that the Octane plugin only supports y up scenes. There is also a problem with the environment rotation that works wrong if working in Z Up.
Any ideas to set the scene nodes (camera ans environment) in a correct Z Up way?
If I set the scene units to millimiters in Maya there are still artefacts on the surfaces wich show typically up in Octane when working in the wrong scale. If I scale the model down, it looks fine.
How can the scene geometry unit interpretation set?
Thank you
R
Refracty
You need to enable the "Verbose mode" and share the render log file and the full content of SE messages. Or share the scene. Otherwise - I have absolutely no info to even guess the reason.
AhmadR
all octane Materials unable to do (Undo),.. like Diffuse,Transmission,Roughness,Bump,... when change any slider,..
thanks,.
Next version HERE.
Return to “Autodesk Maya”
