animated texture? really?
animasyoncumhuriyeti
i just can't belive that i can't use animated texture in the latest version of octane plugin. i missed the deadline because of that seriously simple and core 3d renderer function absence. every time i try to use octane for a production i failed and im really tired of that.
MaTtY631990
Interesting, I could use animated textures in 1.55. Is this gone now completely.
akira
@animasyoncumhuriyeti
Sure it works.
Don't tell me you used a movie file as the animated texture.
keywords: image sequence, IFL
jpg sequence didn't work png sequence didn't work. i never use avi or mov file but even i tried both of them. no solution. maybe in your care is works but i trie everything and im pretty sure mine doesn't work for sure.
akira
jpg, png and tga sequences all work here, tested on 2.16 and 2.23.1 - 1.5 max 2013
test scene attached:
ani_textures.zip
(29.16 MiB) Downloaded 133 times
thanks. it's so interesting that when i create the ifl it adds the full path of the files location and it doesnT work in octane. but when i edit the ifl with only the names of the images it works. setting the scene solves for this situation
Return to “Autodesk 3Ds Max”
