Hi all,
I am trying to run a simple turntable animation, however when i render this out in Octane (2.1) it renders the first frame only 240 times? Is there a how to on set up for animation rendering?
thanks
Animation settings?
Moderator: BK
Animating the camera is possible in 2.1. If you add a camera and parent it to a primitive sphere you can rotate the sphere on it's Y axis to get the turntable effect you're looking for.bpzen wrote:I am trying to run a simple turntable animation, however when i render this out in Octane (2.1) it renders the first frame only 240 times? Is there a how to on set up for animation rendering?
Example animation: http://gfycat.com/DeliriousEthicalGalapagosdove
- thongology
You would be able to do what you're trying to do with 1.2 and your graphic card setup. 1.2 animates with kepler cards such as your titan and 770.bpzen wrote:Hi all,
thanks
EVGA Z97 Classified| 4790K @ 4.7 ghz| 32GB RAM | 2 x Titan X | Windows 8.1 Pro | GeForce Driver 365.19
