OctaneRender™ for Blender 2.23.1 - 8.2 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New 2.23.1 engine.
  • Merged with Blender 2.74.
  • Added "Cube map" mode for panoramic camera.
  • Don't use the stereo mode anymore to disable stereo in the thin-lens camera, but the stereo output setting. This makes the stereo settings of the panoramic and thin-lens cameras consistent.
  • Added option "Pixel aspect ratio" to the thin-lens camera node, which allows you to render to a non-square pixel format (like NTSC or PAL).
  • Added option "Aperture aspect ratio" to the thin-lens camera node, which allows you to stretch/squash the DOF disc.
  • Added pin "Keep upright" to the panoramic camera node. If enabled, the up-vector is kept at (0, 1, 0).
  • Added "Over-under" stereo mode.
  • Added option "Pano blackout latitude" to the panoramic camera node, which defines the minimum latitude (in spherical camera coordinates) at which the rendering is "blacked out", when stereo rendering is enabled. This is to avoid eye strain, when people try to look up or down at the poles.
  • Minor fixes and improvements.
Blender Octane Edition - 8.2 (2.74) (59.9MB autoinstaller file)
Octane Server - 2.23.1 - 8.2 (10.7MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.23.1 - 8.2 (9.1MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
kubicki3d
That's great news, thank you!
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
justavisitor
Super, thank you!
Latest OctaneRender for Blender. Windows 10, i7 quad 3.7GHz, 16GB, 2xTitan.
amadinam
Thank you. Say please when receive priority?
Garquitectos
Many Thanks!
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
r-username
Thanks very much for all the work on the blender plugin,
my only additional want would be tighter integration with octane standalone.
cheers,
stephen
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
vipvip
Thanks a lot
simdal
Thanks Jim! :)
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
marcotronic
Thanks a lot! Great to see 2.74 merged! ;)
Marcotronic - Artist & Composer for Videogame & Film Music http://www.marcotronic.com
mirobimbo
Thanks too for 2.74. Now I am waiting for tighter integration with standalone, it would be great ...
Blender for modeling, editing scenes, standalone for faster viewport and better final tune ...
Sorry my English.
Return to “Blender”
