How import EXR in AE ?
Andygraph3D
i have make update about octane and plugin for export exr ..
but when try to import the file exr in AE the frame is black !
where i wrong ?
I'm not sure AE supports multi-layer EXR. However Nuke does (and there is a non-commercial free version). You can also use http://djv.sourceforge.net/ to check the EXR files are being written as expected.
Andygraph3D
yes AE have support, i have found the way ;-)
but i have see a problem about gamma from png file and exr beauty ..
i need move the gamma level from 1 to 1,8 from have the similar picture.
the png beauty and exr beauty, should not be identical?
It depends how AE handles the EXR's. The Poser plugin will be tonemapping render outputs for the png. Try Imager response Linear or unticking Render Passes->Tonemap.
Andygraph3D
I have unticking Tonemap in render pass
same gamma problem :(
whats you say about "Imager response Linear" ?
Andygraph3D
lol, i use proexr inside after effect ;-)
but i have anyway problem about gamma ..
r-username
If anyone is looking for an alternative to AE
The free version of Fusion has very nice multi-layer EXR support
https://www.blackmagicdesign.com/products/fusion
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
When you export to EXR All Layers, the plugin exports UN-TONEMAPPED (ie. Gamma, Camera Response, Highlight Compression, Saturation and Saturate to White are NOT applied to the saved EXR. So when loaded in AE/Nuke/Fusion, they will load in Linear color space and then color map to whatever you set them to - ie. sRGB = gamma 2.2.
Andygraph3D
tonemapped NOT supported all passes
and in any case the result is modified compared to the original render (beauty png)
original png = gamma 1.0
the EXR tonemapped = gamma 0.45 (from original png gamma)
the EXR All Passes = gamma 1.8 (more some slight color correction from original png)
is not possible export without any gamma correction ?
Return to “Poser”
