Mesh node usable
hi i am currently using 2010 max when i try to export from max to octane, it gives me this error Meshnode for rendering " filename" is not useable. I am using prebeta version 2.3 v5 and i using max2octane_1.022g exporter. thank you for the helps
Win 7 64 | Geforce GTX260 | i7 920 2.67GHz | 6GB
The name of the exported mesh and the meshname in the Octane-file doesn´t match.
Maybe you have renamed a existing project...
face
face
http://vimeo.com/user2509578
you must press "Use existing project" and select your existing project, then you can render the animation.
Hello
