Wishlist: request for Live Viewer
GIOLETS
I ask if is possible in the future to have a button on Live Viewer that set the size of the window at the same ratio of the image output setting.
Could be for my opinion very useful.
Thanks.
Luca
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
There is two option which are similar to your request. Lock to render resolution or safe area lines in Live Viewer. Why don't you use these?
sdanaher
aoktar wrote:There is two option which are similar to your request. Lock to render resolution or safe area lines in Live Viewer. Why don't you use these?
I only see Lock to Render res. Why does it shrink the view when enabled instead of simply cropping to the frame lines? There's loads of black UI space around the view being wasted.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
BLICK3D
It would be great if you could PAN around when >> Lock to render resolution <<is enabled.
For me it always shows the center - or do I miss something here?
