PLaying with daylight and HDR settings
B65ISP
This is my first experience with Octane (demo) and all I can say is: WOW! So easy, so fast and so realistic. Model, UV unwrap - Blender, plants: IVY and particle grass converted to mesh.
Image Image Image
cglittenberg
Nice work!!!
Dr. Carl Glittenberg
Glittenberg Medical Visualizations
Intel(R) Core(TM)i7 CPU 860 @ 2.80Ghz 2.80Ghz 6,00 GB RAM Windows 7 Home Premium Nvidia GeForce GTX 480
radiant
very nice,
btw how do you convert the grass particles to mesh?
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
B65ISP
Here you can see this excellent tutorial "Painting Instanced Objects" and make grass with group of object and particle system:
http://www.blendercookie.com/2009/02/18 ... d-objects/
Or, you can complicate your life with this method (convert particle "string" to mesh) in Blender 2.49:
1. Make your particle grass
2. Convert the particle system into the mesh (in modifier tab)
3. In edit mode select all vertices and go to Mesh/Scripts/Edge to Curve
4. Now, select this new "bundle" of curves and go to Edit mode (delete mesh, we do not need it more)
5. Assign the thickness of the grass with Bevel Depth
6. Deselect all vertices and go to Select/Select/Deselect First
7. With ALT+S go to 50%
8. Add next vertice with Select/Select Next and go again (You have now two vertices per one "string") to 50%
9. Convert Curve to mesh and this is it
My english is not so good but I hope you can understand this short tutorial :)
teecee2107
Interesting work. Some are really nice !!
Return to “Works In Progress”
