Render Priority after hitting Render.
Raoul
Apologies if this has already been asked.
After I hit render, is it possible to go to settings and change the render priority?
ie, if i have a project at LOW.. hit render.. render some frames as I'm working on something else.. then set it to HIGH when I'm done working on the comp – Will it use those new priorities as it continues the render?
Also, does anyone know a good app to monitor GPU usage on a Mac?
Thanks all.
Raoul
Sorry, should have just done some tests before posting. It seems the priority is indeed locked to what it was at when starting the render.
Yes correct. It's rendering with last state and not possible to play with gpu settings while in animation render phase.
