manage out-of-core on master and slave(s)
rappet
I want to use out-of-core rendering while rerndering over the network.
I can enable it in the configuration of the standalone or plugin.
The slaves says "out-of-core rendering disabled"... In the crrrent projec the slave can handle it because it has more vram then the master. But in most cases you would like to enable and disable master and slaves at the same moment.
I know I can enable the "out-of-core rendering" on the slaves by uninstall the dameon and reinstall and with the choice to enable or disable it.
A nicer way would be to have it managed on the master and or plugin without having to re0install?
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
abstrax
rappet wrote:Hi,
greetz,
In the future we will probably add more control to the slaves. For now, the idea is to set up each slave as if the slave computer isn't used by anything else and therefor, the configuration (GPU selection, OOC settings, etc.) are not changing.
