Video in material
Mibu
Hi, is possible put video file in material (for example into diffuse layer)? I know how to do it in Cinema, but I am not successfull in Octane. Thanks a lot.
Mibu wrote:Hi, is possible put video file in material (for example into diffuse layer)? I know how to do it in Cinema, but I am not successfull in Octane. Thanks a lot.
It's not yet supported.
Mibu
Thanks for fast answer, Aoktar.
Fluffy
aoktar wrote:It's not yet supported.
Image sequences seem to work fine, though.
Mibu
It would be nice. How did you load imige sequence?
like that c4d bitmaps how works
Fluffy
Just load the first image of the sequence in the Octane Image texture shader, then go to the Animation tab of the shader and set your frame range and frame rate. Works the same as in C4D.
Mibu
Oh, many thanks, guys! I forgot set frame range :oops:
pxlntwrk
it works here (2.14) with video sequences, just use c4d standard shader in diffuse slot...
pxlntwrk.net
LanceClayton
Whats the best way to do this in 2018 (Octane v3). Tried the Octance Image Texture with JPEG sequence, range set from 0-160 (I have 160 frames) but it never plays from the first frame, always from 25 odd frames in???
Lance
