OctaneRender® for Maya® 2.22.2 - 7.0 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
THIS IS THE QUICK-FIX VERSION
  • Fixed value limits in Octane transform nodes.
CHANGES OF PREVIOUS VERSION
  • New 2.22.2 engine.
  • Added "Set current for IPR" button to camera AE. We can't use the standard Maya's "IPR/IPR Render/<cam name>" menu for that, as Maya always calls the "render stop" and then "render start" again with new camera, so all the geometry is reloaded every time in this case. This is the reason to use the Octane's own button for this. You can use the command "octane -scc <cam name>" from scripts to switch camera during IPR.
  • Added "Light pass ID" attribute to emission nodes.
  • Added over-under stereo mode.
  • Added option "Pixel aspect ratio" to the thin-lens camera node, which allows you to render to a non-square pixel format (like NTSC or PAL).
  • Added option "Aperture aspect ratio" to the thin-lens camera node, which allows you to stretch/squash the DOF disc.
  • Added pin "Keep upright" to the panoramic camera node. If enabled, the up-vector is kept at (0, 1, 0).
  • Added option "Pano blackout latitude" to the panoramic camera node, which defines the minimum latitude (in spherical camera coordinates) at which the rendering is "blacked out", when stereo rendering is enabled. This is to avoid eye strain, when people try to look up or down at the poles.
  • Don't use the stereo mode anymore to disable stereo in the thin-lens camera, but the stereo output setting. This makes the stereo settings of the panoramic and thin-lens cameras consistent.
  • Fixed black body emission loading from Octane DB.
  • Fixed particles instancer bug (rendered the same geometry instances when set to "Scatter").
  • Reworked the Octane's presentation in hypershader mechanizm. Now it does not have issues after stopping to use the Octane plugin. This new mechanizm works in Maya versions starting from 2014.
  • Reworked the Gradient Texture. Don't switch the active critical projects to this major plugin version if you are not ready to re-set the Octane gradient textures in it.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.22.2 - 7.0 (33.8MB autoinstaller file)
OctaneRender for Maya 2.22.2 - 7.0 Demo (30.9MB autoinstaller file)
Standalone: http://render.otoy.com/forum/viewtopic.php?f=33&t=45529
Yours,
The OctaneRender™ Team.
dsyee
Thanks Jim!
FYI, I was still having the Hypershade problem initially with the new version with Octane auto-load turned off. After loading and then unloading the new 7.0 plug-in, then restarting Maya, Hypershade seems to work fine when Octane isn't loaded. Just a heads up for anyone who might run into the same problem!
Core i7-3770 / 16GB RAM / 2x GTX 780 6GB / Windows 7
prodviz
Cheers Jim.
Jolbertoquini
Hi Jim
Just a quick question, This version have a fix of the one sample stuck at the render? Thank you
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
zboog
How do you use the new "Light pass ID" setting? Is this a way to render light passes so that you can adjust the lights in post?
abeoctane
Hi, I found a bug with the specular material, if you connect an absorption medium, change the value of it, and then break the connection with the medium, the specular material don´t change, like the absorption medium is still connected but it is not.
Berge
Will Octane V2 support Maya 2016?
Jolbertoquini
zboog wrote:How do you use the new "Light pass ID" setting? Is this a way to render light passes so that you can adjust the lights in post?
Any one now how to use I guess is the layer...Please, would be good to have a update Maya manual on that.
Thanks :D
Berge wrote:Will Octane V2 support Maya 2016?
Is Maya 2016 already available for all platforms?
Berge
It's out for windows, dont know about the other platforms though.
Return to “Autodesk Maya”
