crashes since 2.22 (Materials?)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
prestesi
Hi Aoktar,
Since the newest release 2.22 and also 2.22.1 (octane), my C4D crashes by loading the scene file. My Scenefile was built in version 2.21.
I can start the scene file, when i in previous version 2.21 some materials delete.
I reproduce this error also with a blank scene and a cubic, when i drag and drop the material "rusted iron" in the render window. Also as download i became a crash.
Is there a specific Problem with Materials?
Thanks for your tests and help.
Daniel
couldn't understand well. is it related with livedb? We have fixed it on plugin 2.22.1. See: http://render.otoy.com/forum/viewtopic.php?f=85&t=45587
prestesi
Hi Aoktar,
My fault. Just with the plugin version 2.22.1 there is no problem more with the live db.
Unfortunately my scene is still a problem.
This happens on two different win7 machines with C4d R16. I will finde out more at home. The result i will post here.
But thanks for your quick response!
Daniel
Ok, let me know the results. It should be well, because i'm using the all my scenes without any problems. I would overlook the somethings here.
prestesi
Hi Aoktar,
As attachment you finde a scene file with only one material. This one makes the problems. There are any native C4D shaders in use. Possible there is the Problem?
I work on two win7 machines C4d R16. With version 2.21 the scene with this material works. In v. 2.22.1 C4D hangs for ever...
I hope, this information help you.
Thanks for your great work!
Daniel
where is your scene?
prestesi
I hope, the scene will be there now...
Daniel
crash with Lack base color.zip
(55.75 KiB) Downloaded 250 times
Return to “Bug Reports”
