will not render past 1st frame
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ArcaneParadigm
octane 2.20 150320 032545.log
(205.55 KiB) Downloaded 265 times
TRying to render an animation
It renders first frame fine takes a minute or two then just starts kicking out frames ( the exact same one) every second
the animation does not progress
it seems to be just saving out the same frame for as many frames as I set to render ??????
I can jump to any frame on the timeline and render it fine
octane 2.20 150320 031732.log
(158.96 KiB) Downloaded 264 times
do you have info passes which is activated?
ArcaneParadigm
i dont think so
i can't see any info to help your problem. What's you version? Can you send me your scene?
ArcaneParadigm
ok so this is what i figured out maybe u can explain
cuz I had resend only updated objects
instead of Send all scene date
so it worked when i changed it to Send all scene data
BUT
then i wanted to turn on motion blur and it switched it back to resend only updated objects and the animation wouldnt work again.
Also I've been scanning the forums trying to find cohesive info on how to get rid of noise - I went thru all the links you put aside and really found very little info in there about how to actually do it
CAn't you post optimized settings for small medium and large scenes that are a starting point for
filter size
Gi clamp
Coheren ration
static nopise on or off
alpha shadows
path term power
its like impossiple to figure out all these different settings as to what is the best
So how do I turn on th emotion BLur if it keeps not letting me render the animation ???
ArcaneParadigm
using octane render 2.20 rc2
ArcaneParadigm
I can send scene but not thru here where any one can grab it
why don't try on 2.21.2? If you have same problem, let me know and send me your scene via PM or mail.
Also please don't ask to me ridding noises. I have posted a lot of help for this. There is lot of discussion for methods. Best is to make some practice and tests. But it's easily possible with some tricks and settings. Check this topic: http://render.otoy.com/forum/viewtopic.php?f=87&t=45341
ArcaneParadigm
I'll try the newer one but I went thru every one of those links and couldnt find any real info on how to deal with the noise -
ArcaneParadigm wrote:I'll try the newer one but I went thru every one of those links and couldnt find any real info on how to deal with the noise -
you can read parameter's info and check what i do to increase render speed. There is a few parameters to do this and only you need to test eachone on some test scenes. What do you expect more?
Return to “Bug Reports”
