OctaneRender v3 announced!
TRRazor
  • Volumetric rendering: OctaneRender 3 supports the ability to render particulate matter such as clouds, smoke, fog, and fire with varying densities and introduces a unique native primitive type for incredibly detailed micro-surface displacement volumes and surfaces required to render photorealistic natural and organic materials. Dreamworks’ OpenVDB is also supported for direct in-camera rendering of particle simulations.
  • Open Shader Language (OpenSL) support: Through OpenSL, content creators have the ability to build their own materials, procedural textures, and shaders, taking advantage of what is quickly becoming an industry standard while maintaining the exceptional performance OctaneRender is known for.
  • OpenCL support: OctaneRender 3 will support the broadest range of processors possible using OpenCL to run on Intel CPUs with support for out-of-core geometry, OpenCL FPGAs and ASICs, and AMD GPUs.
  • Deep pixel rendering: OctaneRender 3 adds deep pixel rendering support, as well as live connecting of DCC and compositing apps through Octane plug-ins for Pixologic’s Zbrush and The Foundry’s NUKE. OctaneRender 3 will also ship with a built in plugin for Adobe Photoshop that will properly handle multi-layer EXR files and support live deep pixel layer composting within Photoshop. Artists can open, create, and save ORBX media files introduced in OctaneRender 3, including planar and volumetric light fields, directly within Adobe Photoshop.
  • Advanced live texture baking: A feature that’s most beneficial for use in real-time game engines, OctaneRender 3 supports unbiased GPU texture baking (UV or volumetric) of global illumination, spherical harmonics and 8D light fields in Unreal Engine 4 and Unity plugins.
  • Infinite mesh and polygon sizes: OctaneRender 3 removes all limits on the maximum allowed primitive and triangle count.
  • FBX and PTEX support: OctaneRender 3 supports importing data from Autodesk’s FBX file format and Disney’s PTEX texture file format.
  • Split render passes, advanced per object reflection controls: OctaneRender 3 allows artists to split render passes into raw lighting and albedo passes, and adds fine-grained reflection, shadow and illumination casting controls per object or layer. These elements can also be built into the export, whether it is a light field, VR scene, or a movie file.
  • Fully configurable: OctaneRender 3 allows fully configurable UI, transform gizmos and dockable windows.
  • New plugin APIs: While previous versions of OctaneRender have support LUA plugins through scripting nodes, OctaneRender 3 adds C plugins and portable LLVM-based API support in ORBX packages.
Some great new and long awaited features in this list!
inlifethrill
Good God!
gazukull
I wish knew how the other hardware are going to perform. I just dropped a ton of loot into new nvidia cards.
Win 8.1 X64 / 6x780GTX / AMD FX-8320 / 32GB RAM
Where do you get this info?
Lewis
aoktar wrote:Where do you get this info?
http://home.otoy.com/otoy-unveils-octan ... -renderer/
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
coilbook
as long as fire and clouds can be used in animations and daylight system will have quick cloud set up like unreal engine
TRRazor
Otoy announced it at GTC 2015 today.
Seems weird seeing such a question come from you, since as a plug-in developers I always thought you guys get to know such things first-hand :?:
samhal
But there is STILL no "make art" button!! :)
Make have to splurge on this.
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
partially we had some info yes
coilbook
is there a video to see octane v3
Return to “Poser”
