OctaneRender™ for Blender 2.21.1 - 7.8 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Improved the Gradient Texture node. Now the standard Blender ramp is used in there.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.8 Linux (96.3MB autoinstaller file)
Next version HERE.
Return to “Blender”
