Panaromic Camera and Depth Map
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pak
Depth map seems to be calculated depending on the position of the camera only - which does not take the FOV into calculation. This becomes very obvious when a 360 degree panoramic lens is used. The places that stay behind the camera (location-wise) do not appear in the depth map.
However I believe the a truly distance based per-pixel calculation would solve the problem.
Return to “Bug Reports”
