How to make a surface Glow / luminant ?
asher
Hello, I use the LW plugin.
I am building a scene with a bunch of TV / LCD screens. I map the image as required on each screen. Now i need it to look as it is turned on / luminant. I n normal Lightwave, all i have to do is add luminace to the surface, to taste, that is all to it.
In octane Nodal mode.....
I have tried using Texture emitor, luminance, etc.... nothing seems to do what i expect. ( TV look )
Texture emitor just adds white, and if overpowered, glows into white.... BUT NOT THE IMAGE that is mapped to it.
So it fades the white with the bitmap, not good.
Connecting something to the Surface luminance input does not work at all either....
Thanks in advance...
GTX TITAN, TITAN Black, 780Ti
WIN 7/64
I7
Asrock Extreme 3 motherboard
profbetis
Are you sure your UV mapping is correct? Check the position/scale of the coordinates, or if it even has them at all.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
asher
the mapping is correct, as i can see it. In this case is cubical.
WIN 7/64
I7
hellguy
Have you tried connecting your image to the Efficiency Pin of the Texture Emission Node?
asher
Thank you Hellguy! That worked! Cheers.
WIN 7/64
I7
