Rendering only material (without any lights or else)
hannesgrebin
Actually I simply want to render the texture without any other parameter at a high resolution. Is there a way to achieve this in Octane? Thx a lot for you input!
formatio
Try with white environment and Direct Lighting with some mode other than AO or diffuse (environment or sth)
Regards, Mac
As Mac suggests - set the Environment to Texture Environment, with a white RGB Color as the texture.
hannesgrebin
Thanks you both, so quick! will do so tmw and keep u posted.
Return to “Rhinoceros 3D”
