OctaneRender™ for Blender 2.21.1 - 7.7 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Improvemed the Preview-Render scene loading speed.
  • Fixed the OpenSubDiv bug: sharpness value was loaded only after first change.
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v7.7 Linux (96.3MB autoinstaller file)
kaiwas
when rendering animation - the first frame is rendered well and the following frames are empty. "waiting for image...."
But maybe a mistake in the scene
Next version HERE.
Return to “Blender”
