The problem: If you have Render Layer OR Layer Masks enabled, and there is an object with Opacity enabled in the scene, any objects behind it will be completely clipped/masked in the Info passes (AO, layer masks etc.). Not in Beauty/Main pass though, which is how it should be!
Example showing the problem:
