Preview size idea
wheelpros
Paul, it would be nice if when in preview it would snap the window size to a percentage of the modo camera size. This way if we have a backplate image in for reference it would not scale to some odd dimension from it original size (assuming that you have set the modo camera to the correct backplate size). 10, 25 and 50 percents might work. Just thinking out loud.
Carter
Hi Carter - if the Viewport is already at the size aspect ratio as the Modo resolution, then in the Modo Preferences->Octane, you can tick "Lock Viewport Aspect Ratio".
Return to “Foundry Modo”
