Hello,
Can someone help me properly setup a JPEG image sequence in an ImageTexture shader? I searched this forum and read through the Octane for Cinema 4D manual without any luck.
My setup is that I have an iPhone screen and I'd like to have it play through an image sequence halfway through my main animation (which is 0 to 134 frames in length). The duration of the phone sequence is 40 frames but I'd like the animation to begin and end during the middle of the main animation (not the sequence itself).
I've dragged the first JPEG in the sequence to the ImageTexture's File but am unsure of how to configure the Animation tab to play through the sequence. It just sits on a single frame no matter what numbers I type into the fields.
Thank you for any help you can offer.
JPEG Image Sequence in ImageTexture
i suppose that not supports the some range of sequence. You should create a seperate clone of images in other place.
