CineRender in ArchiCAD 18
BfPuVAK
Hi Paul,
the Octane plugin is generating its materials from the Archicad Internal-Engine-Material settings now, isn't it?
Is there a plan to let him do this from The CineRender materials?
I'm not very familiar (unfortunately) with C4D itself but AFAIK the settings for this in Archicad are covering
all the settings that are natively in C4D material settings. And Archicad can also import materials from C4D now.
Perhaps you could even use the conversion method already used in C4D-plugin -> Octane?
Greetins,
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
Hi Artur
As far as I know, the C4D material for an AC Surface is not available to an ArchiCAD plugin. So I don't believe this would be possible.
BfPuVAK
...when I render with the CineRender Engine in Archicad, it uses C4D materials in Archicad
and I can even Import them also from an C4D-project:
Don't you have the CineRender in your AC18?
Greets,
Artur
Hi Artur
Rendering plugins (which is what CineRender is) data is not available to other rendering plugins in the ArchiCAD API.
BfPuVAK
Ohh, OK. I unterstand what you mean.
But that's a pity, isnt't it? ;)
Artur
