OctaneRender® for Maya® 2.21.1 - 6.4 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
THIS IS THE QUICK-FIX VERSION
  • Fixed value limits in Octane transform nodes.
CHANGES OF PREVIOUS VERSION
  • Added "out of core" settings to Octane globals.
  • Fixed the hair material UI bug.
  • Fixed the db dialog crash bug (happened if you pressed the "open" button the second time when the dialog was already opened).
  • Fixed the LiveDB crash when loading asset containing scattering medium.
  • Minor fixes...
Installation:
DOWNLOAD
OctaneRender for Maya - v6.4 Linux (18.3MB autoinstaller file)
Standalone: http://render.otoy.com/forum/viewtopic.php?f=33&t=44704
Yours,
The OctaneRender™ Team.
Next version HERE.
Return to “Autodesk Maya”
