Hi I have a simple question,
step 1. I export the sketchup model using sketchup-plugin to octane standalone (save as *.ocs or *.orbx)
step 2. then i make some changes in standalone (like materials, camera position..etc)
step 3. Then I make some more changes in sketchup and export again
when i open the standalone all the changes made in step 2 is gone, is there a way to overcome this problem?
thank you in advance.
Simple export question
I am afraid your ocs scene is being overridden when you re export it. What I would recommend - build your geometry and UV it in Sketchup and then export it to the Standalone and apply texture nodes. I know it's painful. Especially that Bro is so busy and the plugin is not developed as it should. After 3 years with SU I switched to Modo...
